Seat pedestal and mount
Jetech
Iowa
I added a front mount and pedestal to my 1436. The mount base is two 3/16" x 2" alum angles. I added two 7/8" thick treated boards cut at an angle to match the mid seat level to the alum angles using screws. Then a .050 alum sheet was screwed on to the wood pieces and the pedestal was bolted onto that.
I used eight 5/32" Cherry Max rivets to fasten the alum angles to the boat ribs. The wood pieced were coated with epoxy and painted.
The mount is 7 1/2" wide and light and strong.
Nice work, I did something similar to that on my little rig, except I forward mounted battery there. I mounted a pedestal where the original bench was. Used some scrap channel from work, the channel is 6061 aluminum used for portable tow bars for 65 million $ Gulfstream airplanes.
Nice clean battery installation, that looks great. I am going mount the battery in the rear seat with access through a hatch. haven't decided exactly how yet.
Good looking seat base, planning it out makes for a terrific installation, thus the great looking job, well done!
