TIPS ON PUMPING GAS
mtnman
Tionesta Pa.
> TIPS ON PUMPING GAS
> I don't know what you guys are paying for gasoline.... but here in
> California we are also paying higher, up to $3.50 per gallon. But my
> line of work is in petroleum for about 31 years now, so here are some
> tricks to get more of your money's worth for every gallon..
> Here at the Kinder Morgan Pipeline where I work in San Jose, CA we
> deliver about 4 million gallons in a 24-hour period thru the pipeline.
> One day is diesel the next day is jet fuel, and gasoline, regular and
> premium grades. We have 34-storag e tanks here with a total capacity of
& gt; 16,800,000 gallons.
> Only buy or fill up your car or truck in the early morning when the
> ground temperature is still cold. Remember that all service stations
> have their storage tanks buried below ground. The colder the ground
> the more dense the gasoline, when it gets warmer gasoline expands, so
> buying in the afternoon or in the evening....your gallon is not exactly
> a gallon. In the petroleum business, the specific gravity and the
> temperature of the gasoline, diesel and jet fuel, ethanol and other
> petroleum products plays an important role.
> A 1-degree rise in temperature is a big deal for this business. But the
> service stations do not have temperature compensation at the pumps.
> When you're filling up do not squeeze the trigger of the nozzle to a
> fast mode. If you look you will see that the trigger has three> (3)stages: low, middle, and high. In slow mode you should be pumping on
> low speed, thereby minimizing the vapors that are created while you are
> pumping. All hoses at the pump have a vapor return. If you are pumping
> on the fast rate, some other liquid that goes to your tank becomes
> vapor. Those vapors are being sucked up and back into the underground
> storage tank so you're getting less worth for your money.
> One of the most important tips is to fill up when your gas tank is HALF
> FULL or HALF EMPTY. The reason for this is, the more gas you have in
> your tank the less air occupying its empty space. Gasoline evaporates
> faster than you can imagine. Gasoline storage tanks have an internal
> floating roof. This roof serves as zero clearance between the gas and
> the atmosphere, so it minimizes the evaporation. Unlike service
> stations, here where I work, every truck that we load i s te m perature
> compensated so that every gall on is actually the exact amount.
> Another reminder, if there is a gasoline truck pumping into the storage
> tanks when you stop to buy gas, DO NOT fill up--most likely the gasoline
> is being stirred up as the gas is being delivered, and you might pick up
> some of the dirt that normally settles on the bottom. Hope this will
> help you get the most value for your money.
> DO SHARE THESE TIPS WITH OTHERS!
> WHERE TO BUY USA GAS, THIS IS VERY IMPORTANT TO KNOW. READ ON
> Gas rationing in the 80's worked even though we grumbled about it. It
> might even be good for us! The Saudis are boycotting American goods. We
> should return the favor.
> An interesting thought is to boycott their GAS.
> Every time you fill up the car, you can avoid putting more money into
> the coffers of Saudi Arabia. Just buy f ro m gas companies that don't
> import their oil from the Saudis.
> Nothing is more frustrating than the feeling that every time I fill-up
> the tank, I am sending my money to people who are trying to kill me, my
> family, and my friends.
> I thought it might be interesting for you to know which oil companies
> are the best to buy gas from and which major companies import Middle
> Eastern oil.
> These companies import Middle Eastern oil:
> Shell........................... 205,742,000 barrels
> Chevron/Texaco......... 144,332,000 barrels
> Exxon/Mobil............... 130,082,000 barrels
> Marathon/Speedway... 117,740,000 barrels
> Amoco............................62,231,000 barrels
> Citgo gas is from South America, from a Dictator who hates Americans. If
> you do the math at $30/barrel, these imports amoun t t o over $18 BILLION!
> (oil is now $90 - $1 00 a barrel
> Here are some large companies that do not import Middle Eastern oil:
> Sunoco..................0 barrels
> Conoco..................0 barrels
> Sinclair..................0 barrels
> BP/Phillips.............0 barrels
> Hess......................0 barrels
> ARC0.....................0 barrels
> If you go to Sunoco.com , you will get a list of
> the station locations near you.
> All of this information is available from the Department of Energy and
> each is required to state where they get their oil and how much they are
> importing.
