Douglasdzaster
- Joined
- Sep 19, 2020
- Messages
- 780
- Reaction score
- 460
- Location
- Smithville,Texas
- LOCATION
- Smithville, Texas
I have a post about fuel ratio but this deserves it’s own because it’s proof being active with preventative maintenance pays off.
I’m big on taking care of things. Especially if it has an engine.
This one almost got pass me.
When I started my rebuild the first thing I did was install a fuel system. There wasn’t a single fuel filter anywhere on the 1992 40hp Yamaha. Along with other neglect.
I used marine grade A1-15 hose and installed a fuel water separator and an oem filter under the cowl.
I’m getting ready to go fishing in a few days and it’s been a couple months since I had a chance to.
Since last trip I’ve been through tree sap removal from my cover. Then what we call a freeze here in Texas. It stayed below freezing for four days getting down in the teens.
Then it started raining which we desperately needed. But we got it all at once in a long stretch. Report said one week was 14”.
Finally got a dry stretch started today and supposed to be almost a week. As soon as the sun came out today and the cover was dry I took it off the flat bottom.
Sure enough I have some mildew growing all in the stern area and up to the top of the vinyl on the seat and seems to have stopped there. I’ll know tomorrow because I made a flooring system that is easy to remove just for such an occasion.
I went all around the boat looking at everything. I was wondering about the fuel in the lines. Usually I don’t because I only use ethanol free fuel and I buy it from the busiest store for fresh fuel and use Lucas tcw3 synthetic blend oil along with Strar Tron marine he and the occasional splash of sea foam.
I know it’s overboard but I have never had any bad fuel. I just changed the fuel water separator a couple months ago for the first time and there wasn’t even the smallest bubble of water in it and I poured the whole filter into a jar.
I noticed some cracking today in the line at a fitting then at another one. I have the line inside gorilla sleeve so I have to pull it back to look. I removed the clamps from the primer bulbs between it and the separator and caught fuel in a jar. It looks almost clear gasoline no water. Where’s my oil? It’s 50:1. Y’all may look at it and say it’s fine but whenever I take random samples from the carburetors I see a darker tint.
Then I pull the sleeve back and every fitting the line was cracked. One so bad it would have started leaking if I hadn’t caught it. They weren’t like that before the weather. I got my stuff and cut the ends back to good line and reassembled. When I removed the line on the other side of the bulb (engine side) the fuel that ran from the engine side had water. Not much a couple dozen bubbles drifted to the bottom of the jar. The line was not connected to the engine and hasn’t been.
Tomorrow I’m going to do from the tank fitting to the fuel water separator as well as drain all three carburetor’s.
Here’s a couple pictures of the fuel. See if it looks like 2 stroke mix to y’all if you don’t mind.
![BB306244-7D7C-4BFE-859F-F5822836E34B.jpeg BB306244-7D7C-4BFE-859F-F5822836E34B.jpeg](https://cdn.imagearchive.com/tinboats/data/attachments/100/100815-912d2ce7badbb54fe152ff081f343f6e.jpg)
![A428482A-A297-42AE-8B26-7DD87F424247.jpeg A428482A-A297-42AE-8B26-7DD87F424247.jpeg](https://cdn.imagearchive.com/tinboats/data/attachments/100/100816-d2322a134a05560ca557fa940a1197e5.jpg)
The one I used the towel for the background reminds me of moonshine.
![4ABFBA1C-F2AD-4A5F-8010-7983F7CDE29F.jpeg 4ABFBA1C-F2AD-4A5F-8010-7983F7CDE29F.jpeg](https://cdn.imagearchive.com/tinboats/data/attachments/100/100817-cf4e71c44d504bfa2ab38bbc17fc7d93.jpg)
