It is currently 30 Mar 2017, 02:38
 Page 1 of 3 [ 31 posts ]  Go to page 1, 2, 3  Next
PostPosted: 20 Feb 2010, 23:36
After about 2 months of grueling stripping, sanding, sealing, cutting, nailing and carpeting, I HAVE FINALLY FINISHED!! I did ok about taking pictures in the begining but slacked off in the middle. I do have some pictures of the finished product so you can get the basic idea. Thanks for looking!
This is basically how I got the boat and trailer. At this point I had already started to remove the brown paint from tthe trailer.
Stripping the paint off the fenders and frame of the trailer.
Trailer is near completion. I stripped, sanded and painted everthing as well as a new winch, new running boards, carpet, lights, wheeles and tires.
Boat before mod. The owner did a great job on the casting decks but the color just wasn't for me. Plust there was a few things i wanted to change. Replaced all 2x4s with 2x2s to lighten the load. Also decks were built using OSB and I wanted to replace with plywood.
Tearing out the decks.
I didn't take any pictures of the actual build. It was freezing and raining most of the time and took everything I had just to convince myself to go out and work on it. Here is the finished product though. I tore out EVERYTHING. Patched every rivet with West Marine's aluminum epoxy. (expensive at $20 a tube but definately worth it!) Stripped and sanded and painted every square inch of the boat, rebuilt transom, all framing, decks and new carpet. Used piano hinges on the two deck compartments and built a carpeted lid/battery compartment. Lastly I added new posts and seats. I still have a few things I want to do such as wire for lights and add depth finder, but over all I AM DONE!! I love the finished product and had a blast during the whole process. Hope ya like it! Thanks for everyone's input. Thanks REDTAIL for helping with the decks and ideas for a better build!
Personally, I carry a gun because I'm too young to die and too old to take a whoopin'
PostPosted: 20 Feb 2010, 23:42
Is that the same boat? It can't be?
You do good work for sure.
=D> =D> =D> =D> =D> =D>
eezerz
Looks sharp.
So did you sandblast the boat and trailer?
Brine Craft - 16ft Mod V
PostPosted: 20 Feb 2010, 23:43
Looks Great!!!!!!!
PostPosted: 20 Feb 2010, 23:48
Thanks guys! Means alot! No, I never got to sand blast, the funding just wasn't there. :lol: Just alot of stripping and sanding. Got some aircraft paint remover like you guys said and it worked a heck of alot better than the standard stripper.
PostPosted: 20 Feb 2010, 23:50
Great work! =D>
Would never know it's the same boat looking at the before pics.
PostPosted: 20 Feb 2010, 23:51
Did you use 3/4 inch plyboard???
PostPosted: 20 Feb 2010, 23:56
No, I used 7/16. I was trying to lighten it up as much as I could. I was a little leary about using such a thin sheet, but the bracing underneith is pretty stout and it actually turned out pretty sturdy.
PostPosted: 21 Feb 2010, 00:00
Is that a 1232 or a 1236?? I have a 1236 that I used 1/2 worked great. It started to bow a little after a year. Still pretty sturdy.
PostPosted: 21 Feb 2010, 00:04
It is a 1236 Sears Gamefisher. Yeah, bowing is definately my biggest fear. I'm gonna see how she does with the weight in there now, and if/when I ever have to replace the decks, i'll probably go with some thicker stuff.
PostPosted: 21 Feb 2010, 00:09
I just bought a 1448 that Im in the process of decking out. Im going to use 3/4 plyboard. Im going to sell my 1236 crestliner. Its been a great boat, I actually fished out of it today. It really does good with the 9.9 pushing her.
PostPosted: 21 Feb 2010, 01:13
So u used aluminum epoxy to seal leaky rivets...I just bought some loctite marine epoxy, you think this would work good as well? I am very new to this restoring jonboats thing.
Boat:
1985 PolarKraft 1440 Project
Trailer:
1973 Cox Breakaway
Pulling Rig:
2006 Ford Ranger XLT Supercab 4x4
PostPosted: 21 Feb 2010, 01:24
marine epoxy is marine epoxy in that situation...
Tracker TX17~40HP Force
Past Projects:
1648~40HP Mariner
1432~45lb MG
Michimaniac
PostPosted: 21 Feb 2010, 01:49
What do u mean? Sorry man, like I said I am VERY new to this. My very first boat mod. I don't know what peoples opinions are on marine epoxy. I have seached and seen all kinds of different ways to fix rivets. One way is to "rebuck" them and seal. I've seen others have theirs welded. I am leaning that way on two front rivets but I'm not sure. What do u think?
Boat:
Trailer:
1973 Cox Breakaway
Pulling Rig:
PostPosted: 21 Feb 2010, 09:16
Good work...boat looks brand new.
My 1436 ReBuild
http://www.tinboats.net/forum/viewtopic.php?f=21&t=12773
Users browsing this forum: MSNbot Media, Yahoo [Bot] and 55 guests
mud-skipper
