1448 Gregor brought back to life
evansjoem
gutting the pig
Forming a front deck
then the rear deck
Got some sealer to waterproof the deck
Will adding more foam help me draft shallower
Tig welded float pots on
with a home built mud motor
Any suggestions??? I hate the exposed hinges. Maybe get piano hinges and hide them
It is an old 1448 Gregor. I am currently getting 12mph I think it's a 9.9hp can I go bigger
And it starts first pull great motor! ( worn prop) though I have a two blade and a three blade, both are used
You certainly can go bigger. My 12 ft. Gregor was rated at 15 hp (1979), but i found my 9.9 was plenty. If there is still a data plate on the transom, it might have the max hp rating.
