Frogs and Toads
aeviaanah said:
[url=https://www.tinboats.net/forum/viewtopic.php?p=362665#p362665 said:
Captain Ahab » 5 minutes ago[/url]"]
[url=https://www.tinboats.net/forum/viewtopic.php?p=362619#p362619 said:
aeviaanah » Thu Aug 07, 2014 2:02 pm[/url]"]Ive been wanting to get into top water fishing, when is a good time of year to utilize this technique?
Also, do you bring frog to weed end similar to worm technique and expect the bite to occur there? Will they bite through thick floating weeds (thick as you can stand on)?
The hotter the better for this type of fishing - but where you are probably all year round
And yes - they will crash right through the weeds.
I prefer dark or close to dark for the best action
I tried a few casts today but quickly went to my go to bait. I'll give it some time later...
Should I spend time working the weed bed or the area where the bed breaks?
Sorry - I just saw this post - do not know if in GA the temps still are hot enough for topwater frogs - I assume that they are for at least part of the day.
I like to use the frogs in the super thick stuff - drag it across the weeds and the bass will blow up to get it!
Sometimes a fast retrieve causes then to react - other days I pull it from opening to opening letting it fall
I like to swim the edges of weed beds in low light conditions - night time it the right time!
