Help identifying a boat
MattA
Hobbs NM
Hello everyone I just acquired a 1961 Texas Maid boat but I can't find anything on it. Title says model is a Maid but I know that's not right. Any help would be appreciated.
If the title reads “Maid”, and the data plate reads “Texas Maid”, why do you believe it is not a Maid, or Texas Maid. It sounds like a little play on words. Texas Boat Manufacturing Company INC, manufactured a boat in Texas, the boat was made in Texas, hence the Texas Maid.
I like the lines and hull shape, nice boat!
It's a Texas Maid built but that's not the model. If been looking up information but its very limited since they went out of business. What I found is its a 1960 Texas Maid Standard . When they did the title it somehow got wrong information on it. No telling how many different people owned it lol.
You are looking for the model not the make. Try searching images online. Search for Texas Boat MFG and also for Texas Maid and scan until you see one with those distinctive gunnel supports.
I had a boat years ago, and didn't even know if that corner cap that said "Crestliner" came with the boat. I searched Crestliner, and eventually discovered a pic of a little speed boat, with a front hood and seats like a car. Turned out, I had a 1957 Crestliner Viking that someone had gutted, cut the hood off, and turned it into a jon boat. It was worth the time searching for it.
I hope you can find which model you have. It's distinctive looking, which may make it easier.
I finally found some old brochures on line with measurements. And it appears to be a 1960 standard. what do y'all think ?
100% Texas Maid as evidenced by the diamond-oriented bow sheet. All models of TM had that distinctive rivet pattern. Pretty interesting company chartered by 5 Lone Star executives in 1957 - including RW McDonnell.
I think you're spot-on with the 1960 Standard ID.
The 22hp cap is a good confirmation.
**Edit: the 1959 Standard also was rated for 22hp.
The Standard apparently ran from '57 to '61 when it was replaced with the Rio Rey.
Only '59 and '60 were a 22hp rating. The trade sheets from '59 state a 61in beam and the sheet from '60 shows a 60in beam (below). All other measurements were the same.
Color scheme might dial it in if one could find some old literature that shows it. (your boat appears to have some remnants of the factory design still showing)
(fwiw, I have a '57 TM Osprey and the serial was stamped on the outside starboard transom, literally in the rub rail. I'm unsure if that would be a consistent location, though.)
Well done a little work on the boat ordered some Baltic birtch and sealed it with marine one selent and have started cleaning it up getting ready to seal rivets with gluvit. Don't have any leaks that if found so far been able to take it out couple times after I got my rod holders in. Now to order more wood and go ahead and rebuild transom to have all new wood before I seal and paint it.
Is the Baltic Birch made with waterproof glue? Maybe you should test some.
Some Baltic Birch is produced as marine grade plywood. If that is what you ordered, it's good stuff.
Ask your supplier directly. If you ordered it as a marine or exterior grade ply, it should be great to work with.
Aw, that I didn't know. Thanks for the info.
I checked with a local hardwood supplier. They list the traditional 5x5 sheets as interior grade. They also say exterior grade is available in 4x8 sheets.
I love working with baltic birch. No voids and superior laminations. It mills like a dream.
No big deal, go ahead and use what you have. It might last a lot longer than what you think !! Who knows what the future holds....in a couple years you might decide to have a 28' cabin cruiser instead !!
Buzz Kill Alert! Baltic birch is terrific stuff, but I question that it is an exterior grade plywood. Better seal the heck out of it.
I put 3 coats of sealant so we'll see what happens. And I got the wood for less then $160 and already cut at at 15"x60" so just had to cut the length down. So if they'll last couple years then I'll be happy.
