Attwanl
I have a 12/36 alumacraft and an older 12/48 wooden jon... I like them both, but would like to have a 14/48.
[url=https://www.tinboats.net/forum/viewtopic.php?p=322606#p322606 said:DrNip » Today, 21:06[/url]"]If I get the 14' then I have the dreaded question, semi-vee or flat. The semi-vee is only $135 more.
Also I only have 6' bunks with a 2' jon boat cross bunk at the front. Would this be enough or do I need longer bunks?
[url=https://www.tinboats.net/forum/viewtopic.php?p=322610#p322610 said:Scott1298 » 31 minutes ago[/url]"]You might as learn this now... B.O.A.T. stands for "BRING OUT ANOTHER THOUSAND $$$$"!
[url=https://www.tinboats.net/forum/viewtopic.php?p=322620#p322620 said:joseph101088 » 3 minutes ago[/url]"][url=https://www.tinboats.net/forum/viewtopic.php?p=322606#p322606 said:DrNip » Today, 21:06[/url]"]If I get the 14' then I have the dreaded question, semi-vee or flat. The semi-vee is only $135 more.
this question really depends on how far the back of the bunks are from the front stop/winch. if the aft end of the bunk is 12-14 feet from where the front of the boat will be you will be fine. you just dont want the back bouncing and not braced if you have an engine on it.
DrNip said:Anyone? I decided against the splashwell but am still wondering about the extra transom brace. Is it necessary? I assume it is just an extra piece of aluminum on the transom the size of the outboard mounting area or at least this is what it looks like in pics.
