Earlo
Recently picked up a 9.5 Johnson off of CL. Runs great so far. I've replaced the fuel lines with ethanol resistant ones, and have changed the lower unit oil. I was going to tackle the impeller next, but never having done one before, I'm wondering about a couple of aspects. When I changed the lower unit oil, it was kind of a milky light green color, indicating water, but I have no idea when the oil was last changed. I'm guessing I need to replace some seals when doing the impeller, but don't know which ones would address the issue.
https://www.marineengine.com/newparts/part_search.php?part_num=379765&x=16&y=8
The above link shows an impeller kit, but gives no description of what's included.
https://www.marineengine.com/newparts/part_search.php?part_num=382296&x=21&y=11
This link shows a water pump kit, but this may be more than what I need.
https://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1968&hp=9.5&model=MQ-14D&manufacturer=Johnson§ion=Gearcase+Group
Finally this link shows the entire gearcase group. If someone could make a recommendation, I appreciate it.
