huntingbronco
- Joined
- Dec 24, 2010
- Messages
- 70
- Reaction score
- 0
Hey Motorheads - I am seeking wisdom. I have a project boat and it came with this motor. I was really hoping to make it work, but I am having doubts. The wiring in the boat is a mess. To get a sense of the motor, I jumped the starter directly to see if it would turn over. With the spark plugs removed, it turned over really well. With the plugs installed, it would turn over, but very slowly. This is with the battery from my truck, which turns its V10 over just fine. I was jumping post to post straight through the starter.
I pulled the starter and took it apart. Cleaned everything up, brushes looked good. As part of the reinstall, I soldered in splices to repair the badly cracked wiring. A common problem on this vintage engine, I believe. Anyway, the motor still turns over very slowly. (Too slowly to start. BTW- I was never expecting it to fire. Just trying to roll it over.)
Anyway, I am starting to have second thoughts. I really need tilt/trim and I would like a reliable motor. As you can see, the skeg is also broken. So, as I see it, I am going to spend $600 for tilt/trim and $100 skeg repair - and that is before I get it running. I know it ran 5 years ago, but it was left unattended since that time...no telling how she stands today. Gear selector seems functional, as it would turn the prop correctly with the starter turning everything over.
Here's the motor, note the skeg:
Here's what the wiring looked like when I removed up the engine cover.
So what do you guys think? Fix her up or what? Or am I better off picking up a newer used 40hp with factory trim/tilt? Does this motor have a
![boat1-1.jpg](https://proxy.imagearchive.com/956/9565d02d7e73266110b818126df57af7.jpg)
![wiring600x450.jpg](https://proxy.imagearchive.com/585/58590467dcf0aa83ec27530389c9ee6b.jpg)
