Stimputello
- Joined
- Feb 5, 2024
- Messages
- 16
- Reaction score
- 25
- LOCATION
- Yorktown, VA
So I have acquired a decent hull for the right price and am doing a full restoration with my brother and hoping to get the boat on the water by July. Transom was looking very dicey due to old pressure treated wood, but the rest of the hull is pretty spotless albeit some minor corrosion from carpet bunks.
Here are the plan's so far:
- Anneal/fit a new transom due to an unhealthy amount of corrosion
- Fabricate an all aluminum transom with my Tig from some spare aluminum sheets a buddy spared me
- Paint interior/exterior after Alodine treatment and zinc chromate primer
- Foam the boat to be unsinkable because it will get flats usage and light bay usage when whether permits
- Extend casting deck and add storage underneath
- Replace all flooring due to rot, seal with epoxy, then cover with raptor liner for more water resistance and UV protection
- Remove factory rod locker and install new rod storage for more floor space and easier access to rods
- Re-wire electronics, livewell, and re-locate bilge pump outflows
