heavy-chevy
though it was just because it was a long shaft but i made a riser so the cavitation plate sits even with the bottom of the boat and that didn't fix the problem, its still a turd even with one person in it. it runs fine in neutral and revs out but in gear it just lugs, feels like it wont break 3-4k rpm, never fully plains. the prop is a 10x13 could that be the problem? i cleaned the carb changed the plugs, and it compression tested 115psi both cylinders. what do you guys think?
