Nlawson0017
i have a 2010-2011 mercury 60-40 jet that will sound a alarm that is a solid beep for 5-10 seconds and then quits sounding. it happens at random times. i have idled for 10 mins and then a 3/4 throttle runs for a few miles and then back to a idle for a min it will sounds a alarm. ill shut the motor off for 10 mins and return back to the dock and nothing happens. then when idling to just get it back on the trailer it will go off again. i have replaced impeller and t-stat then went to a idle only lake and it never went off, then when returning to the river it does the same thing, alarm goes off after a run but only when i return to a idle speed for a min or so idling into a cove.
i just pulled the jet back off and checked the grommet on the impeller housing and impeller and t-stat and all looks good.
if anyone has any insight to my problems or tips please chime in. i have no idea if really getting hot or low oil pressure because i dont have a manual to tell me what a constant beep is for.
do these sensors ever go bad on these motors?
btw motor is peeing other than takes 5 or 10 seconds after startup.
