So I recently fixed the electrical problem on my 20 hp. It runs pretty **** good now and starts really well. I went to the lake today to test her out and all went well till I opened her up. It had a little hesitation to get moving but I got to speed and off i went. The motor seemed to skip and the wot revved the motor really high. The transmission popped out of gear? I throttled down to shift it back into forward and the shift lever wouldn't move, it was stuck in the forward position...? I turn the engine off and tried to see what might have happened? I was able to get it into neutral again and started the motor right up first pull. As i shifted the motor into forward I started going backwards? The shift lever is stuck in the forward position right now. If I gave it any gas I went backwards not forward? I am not sure what needs to be fixed or where to start? I was looking for vids to watch so I can see what needs to be done. Also to find out what I might need to order to get this next part of the repair started...? I have looked at the diagrams from marineengine.com so I can see the parts. My main issue is I have never tackled something like this before. I am clueless as to where I should start, or what actually needs to be replaced... ANY AND ALL HELP WILL BE GREATLY APPRECIATED.
Thanks,
Capt Root Rat
Motor 20R72R
Johnson 20hp
Thanks,
Capt Root Rat
Motor 20R72R
Johnson 20hp
