Archery help
Loggerhead Mike
franklin, nc
I traded for a new bt assasin acouple weeks ago ( I know that's a sin right in the middle of bow season)
Got it broke in, tuned and starting to get comfortable with it but I'm having a problem wanting to hold the pin right above the bullseye. When I force it down I tend to punch the release.
I've tryed bringing it down, going up, different hand positions ect.
Somebody told me to try a weighted stab. We don't have proshops close so I was hoping anybody with first hand experiance could recomend one.
Needs to be black, short enough to bowhunt and shoot indoor leage in the bowhunters class.
Any openions are much appreciated.
Next on this list is throwing this hostage rest in the trash. They are a pita to tune with
Sounds Like you need to adjust your tiller. Start by making sure your limb bolts are adjusted evenly. I will attach an explanation of tiller. I didn't write this up but it is a good explanation of what you are seeing and how to fix it. Or Google "adjust Bow tiller".
If the grip, arrow rest and nock point were all centered in the bow, then even tiller would be perfect. But it's not that way. The grip is below the arrow, below the nock point and below center in the riser. So you're putting pulling forcein one plane, pushing forcein another.
Generally, consider the riser a lever and the grip as the fulcrum. The grip/fulcrum is closer to the bottom end of the riser than to the top end. So the top end of the lever is longer than the bottom. Basic gradeschool physic tells us that the top end has greater mechanical advantage and we either have to increase the weight on the bottom end, or decrease the weight on the top end, in order to balance the lever over the fulcrum.
But if you would prefer to leave the physics out of it (and I really hope you would prefer it) there is an easy way to see it. Just pick up your bow, aim a sight pin at a point on the wall and, slowly, begin drawing straight back. If you've got your bow set at even tiller, the effect should be immediate as soon as you apply the first bit of drawing force.
The bow will rock back in your hand and the pin will lift up, off the spot. The reason is the top limb, on the long end of the lever, has more mechanical advantage than the bottom limb and is overpowering it. Now, if you pull on back through the breakover to full draw, stabilize the hold on the spot and release an arrow, what do you think that bow is going to do? It will do exactly the same on the shot as it did during the draw! The bow will rock in your hand again during the shot.
The result is you will feel the bow's movement as shock or vibration. It might make more noise than it should.Your bow will be harder to hold on target than it should be, with the limbs straining and fighting against each other. You will have a harder time tuning the bow because you have to fiddle around with adjustments until you find the exact spot in that rocking motion where the arrow finally leaves the bow. The bow's rocking motion guarantees your nock travel will not - CAN NOT - be straight and level.
So, what to do? Well, assuming the pin lifts UP off the target, you add weight to the bottom limb bolt, reduce the weight on the top limb bolt or both. You make a small adjustment, like 1/4 to 1/2 turn, then repeat the 'pick a spot and draw' test. You keep adjusting until you can put that pin on it's spot and draw straight back without it wanting to either lift up off the target or sink below it.
That's a simple, down and dirty way to adjust the bow's dynamic tiller, to custom match your individual grip. There are other, more complicated and involved ways of doing it, but this is very easy and plenty good enough for all but the very best, world class type shooters.
As I've mentioned, it will keep the bow from rocking at the shot. So, you will feel less recoil and vibration during the shot. It will make the bow holdmore steady and stable during aiming. It will make the bow easier to tune because you're not having to compensate for the rocking motion and your nock movement is straighter and more level. It will likely make the bow quieter. In fact, with the limbs balanced and working together during the shot, it is very likely that you will see a smallincrease in arrow speed, even though you might have reduced your draw weight by a couple of pounds.
Some say tiller doesn't matter on single cam bows and I've always said that's a load of rubbish. It works just the same on any bow, no matter what style cam(s) it has.
Now, doing this tiller adjustment will most likely cause your nockset to move, so you might not want to mess with it until after hunting season is over. You will also have to move your peep and any other string mounted anchor references (like a kisser). But the time you save in tuning your arrow flight will more than offset the time it takes to do this.
Don't know if this will help, but it sounds like this problem could be as simple as the peep position on your bowstring. It would be easy enough to check by drawing to your anchor point with your eyes shut and then open your eyes to verify the peep is directly lined up to your dominant eye. Would'nt take long to check out and may save you from other hassles.
Thanks a lot fellers
I'll double check the peep tonight.
The bows a dual cam, I understand what you mean about the physics of the bow, I'd never thaught about that. The limb bolts are maxed out. If I needed to tweak the top bolt, will that have any negative affect on timing? I appreciate yalls advise, very interesting
RiverBottomOutdoors said:
Sounds to me like target panic. We all get it. Adjusting the bow setup won't help that. There a lot of tips and tricks out there on how to overcome it.
x2
I had same problem
To cure problem practiced with a back tension release. It forced me to follow thru better and eliminated problem.
Not exactly panic, I've had it before. I can take my old bow and shoot x's. This new bow I'm wanting to hold about an inch high. I'm Chalking it up to being a new bow and not used to the feel. I group to good to be panic shooting
I still think its target panic. The term panic is somewhat misleading. What you describe matches the definition of it. One form of target panic is having trouble putting the pin on the bullseye. I've had the exact same symptom.
I've been shooting the fire out if it lately, I think your rite. My old bow feels like home when I draw and settle on the dot, when I shoot this newn Ive noticed I'm not as steady.
Im getting better with it every day. Think I just need some more seat time. Its been great for hunting, I may go back to a longer ata bow for Indoor leage though
Bp- yeah, its a bowtech assasin, comes ready to shoot
The problem I had is that I would hold the pin just below the bull and it was all I could do to force myself to move the pin up to the bull and hold. I practiced my way out of it by drawing and anchoring with my eyes closed....for some reason that helped. Glad to say I'm past that problem.
I know I'm way behind the times on this post but you might try some target practice while closing your eyes. I have had the same problem with "jumping on the shot". Start a couple steps from the target, draw, aim, close your eyes and release the arrow. Seems like a few times of this helps me out. Also shooting dots too much and I'm back to this problem, helps to change up targets when possible.
