best trolling motor for the money
ericshayes
I have a 1432 that is being worked on and I need a trolling motor for spring. I am on a budget, but I don't want something that will break or be underpowered. I'll be using it in electric only lakes and ponds. What do you recommend? Thanks
45lb thrust or above
my best advice is to stay away from the MG varimax. Another TB member and I both had problems with them.
I found a used minn kota power drive for 150. Are these good motors? It has 50 pounds of thrust.
the power drive motors do not respond as quickly as the regular foot control motors do . you need to anticipate trouble and start you turn early. they also have more moving parts than a hand control motor.
these are a few thing to think about when buying a used motor..
you may want to check into a reconditioned motor they save you money and have a warranty.
As for size I would suggest the biggest motor your budget has room for.
