13rannon
Hi, I'm new...was wonderin if you could help me identify this boat.
This picture is all I have to go off of. Thank you in advance.
![010210010305011600200809077d51619db.jpg](https://proxy.imagearchive.com/141/141ea09def7e65e78a45dca1a755561a.jpg)
Your exactly right. I was basing it off the chine and transom shape. The difference is the rivet line working up the side of the bow, that the Alumacraft lacks.bobessary said:it looks like an old larson runabout
ben2go said:I agree with the guys on the jon,buuutttttt,I would choose the V hull.The jon in the middle has entirely to high of sides.You'd have to lean way over to pull a fish out of the water.After a while of your arm and side rubbing the side of the boat ,you'll get sore.I learn this the hard way.
Jim said:ben2go said:I agree with the guys on the jon,buuutttttt,I would choose the V hull.The jon in the middle has entirely to high of sides.You'd have to lean way over to pull a fish out of the water.After a while of your arm and side rubbing the side of the boat ,you'll get sore.I learn this the hard way.
I was thinking the same thing, but then it could possibly be a bad picture compression doing that?
13rannon said:That one I don't know about...I'm suppose to go see it tonight.
