Bow eye / winch hook question.
mysavioreigns
I've got a small problem (I hope) in that, the hook on my winch is not big enough to fit around the front handle on my boat. See the picture below to see what I mean:
I've contemplated a few things, but do you guys have any suggestions? I thought about putting a big carabiner or something similar to this:
and then hook the winch-hook onto that, but I'm not sure.
Has anyone else run into this? I really don't want to install a new bow-eye because anywhere below that handle is hard to get to, and the handle is very solid.
Thanks
I use the same thing on my jon boat because my snap hook is too thick to fit my bow eye. So I attached a large quick link(what you have pictured) to my bow eye, then hook up to the quick link.
Actually it's a maillon :)
I ended up finding one in the trailer department at Northern tool (similar to that picture), and put that on last night. Worked well, and with the added benefit that it straightens the strap (previously it was turned 90*, which I did not like). It's rated up to 3,500 pounds, so that should work! Hopefully I can get a picture of the newly-fabricated trailer up soon.
