malaki
A freind mounted his on his trolling motor jammed it into a rock. It broke the eye completely off. Any ideas on how to mount it to the transome with no monting hole?
Charlie Two Tracks said:I just did mine yesterday. I used a product called Plastic Weld. It is a two part epoxy. I set the transducer in a cardboard box in case of spills and put the hose clamp through the one remaining slot. I had roughed up the bottom of the transducer with some coarse sand paper. I mixed the epoxy and applied it with a wooden stick to the bottom of the transducer. Once applied, I raised up the hose clamp a little so it was floating the the epoxy. I let it dry overnight and this morning it looks as if it will work quite well. I put it on the trolling motor and it seems to be hoding quite well. I used all of the two part epoxy. More is better I think.
Jim said:
