S10ssguy said:Run your 12v ignition wire (usually red) through your switch, the constant 12v (usually yellow) straight to the battery, your ground (usually black) to the battery. The speaker wires will be two of the same color (one with a "tracer" color strip on it, for the negative). Hook em up, crank some tunes. Putting one on my boat once I get the sheetmetal case built for it.
hkmp5s said:I have a kenwood from walmart mounted under my side console in one of these.
hkmp5s...what brand is these stereo gimble and where did you buy it from...and don't mind me asking...how much.I have a stereo gimble from BPS and one of the lid/face hinges snapped...i hate cheaply made stuff,the one you have in the picture looks more sturdy.
Thank you
Dan
I'm running 2 polk db691 6x9's and its working great.
On a side note I bought the extended warranty from walmart for $6 in case it gets fried. I haven't installed an antenna yet but I have a hidden one on order. My neighbor uses them in his cooler radios so it should work good.
Most of the time I use the front imputs and just run my mp3 player.
wihil said:S10ssguy said:Run your 12v ignition wire (usually red) through your switch, the constant 12v (usually yellow) straight to the battery, your ground (usually black) to the battery. The speaker wires will be two of the same color (one with a "tracer" color strip on it, for the negative). Hook em up, crank some tunes. Putting one on my boat once I get the sheetmetal case built for it.
Correct answer right here - If you just want it on to test, hook both the red and yellow up to the + terminal and the black to the (-). If you're not sure which one is supposed to be switched, look for the fuse. Every aftermarket radio harness has a fuse on the constant lead.
I went the cheap route - old boombox - but tunes on the water is always a nice thing if it's not too loud.
C
Butthead said:wihil said:S10ssguy said:Run your 12v ignition wire (usually red) through your switch, the constant 12v (usually yellow) straight to the battery, your ground (usually black) to the battery. The speaker wires will be two of the same color (one with a "tracer" color strip on it, for the negative). Hook em up, crank some tunes. Putting one on my boat once I get the sheetmetal case built for it.
C
How loud is too loud? :mrgreen:
Wallijig said:Butthead said:wihil said:I went the cheap route - old boombox - but tunes on the water is always a nice thing if it's not too loud.
C
To loud LOL
I have done a boat with four kicker 15" subwoofers with six 6" speakers with tweeters, two PPI1000 watt amps, & a PPI 600watt amp. we had 6 gel cell batteries & separate alternator for sound system. Now that was loud. I used to do custom car audio before starting my custom home company.
It was a ski party boat. Few months after it was done I seen guy who owned on news, cuffed in perp row headed for court for being a bookie & heard all his assets now below to state now.
