Cushions on deck
answer3
Somerville MA
I am currently making a deck for my 14ft v hull lowe 1467 boat. I put the structural aluminum tubes and plywood on top of it. Now I would like to add some cushions/foam on the sides of the hull to make this area more comfortable for seating and laying around in the front of the boat. I put some pillows just to have an idea of what it would look like (see picture below) as a test. Now I need to buy the foam and put some waterproof tissue on top if the foam/cushions so I can attach them to the deck and leave them permanently on the boat without them taking up water.
Which kind of foam and tissue would you recommend for that?
    47.5 KB
    47.9 KB
On a cabin cruiser boat that I've been building I have also been thinking about how I would make cushions for the bow area.
I have not actually tried this yet, but my plan was to buy a cheap memory foam matress and cut my cushions from it.
https://www.amazon.com/Sleep-Master-6-Inch-Therapeutic-Mattress/dp/B005G02ESA/ref=sr_1_1?s=furniture&ie=UTF8&qid=1426878487&sr=1-1&keywords=foam+mattress
Then I was going to cover them in waterproof vinyl. I don't know exactly what you have in mind, but I was going to make 1/4" plywood bases for my cushions that fit the contour of the boat, and just staple the vinyl to the bottom. Very simple.
