Does my wiring diagram jive?
Silverad04
KCMO
Will someone kindly find a problem with my diagram...Thanx -Rob
No ground terminal shown on the charger ac plug :LOL2:
In all seriousness, it looks good to me. Are those motor cables for starting? Gauge is not shown on those cables.
Tim
All looks good except for the trolling motor.I think you need the fuse before the switch,this way it will save the switch also.maybe I'm wrong or maybe I'm right
[url=https://www.tinboats.net/forum/viewtopic.php?p=350459#p350459 said:
jerseyjimk » Mon Apr 28, 2014 6:58 pm[/url]"]All looks good except for the trolling motor.I think you need the fuse before the switch,this way it will save the switch also.maybe I'm wrong or maybe I'm right
x2 on this.
Don't need a switch on the TM unless you're gonna hard wire it to the power supply wires. Most TM's have the plug/receptacle which acts as a switch in my mind. I always unplug the TM when I load up anyways.
[url=https://www.tinboats.net/forum/viewtopic.php?p=350395#p350395 said:
earl60446 » Today, 10:30[/url]"]No ground terminal shown on the charger ac plug :LOL2:
Tim
Yes sir they are, they are already on the motor.
[url=https://www.tinboats.net/forum/viewtopic.php?p=350467#p350467 said:
TNtroller » 47 minutes ago[/url]"]
x2 on this.
I'll look into buying a plug for it. Thanks for the help fellas
Might want to consider a 60 amp circuit breaker for the trolling motor. Just in case it trips you can reset it and not have to worry about carrying extra fuses.
