deermaster
- Joined
- Feb 1, 2009
- Messages
- 32
- Reaction score
- 0
i have asked this on several forumms, and have gotton so many different answers, i am just as confused as before. i have a 15' starcraft vee hull, made in 1963, and other than some corrosion on the transom that you good folks are helping me with, its a really solid boat. i want to get a trolling motor, and use only that to hunt and fish with for a season, so i can save for a new outboard. the thing is, i am in college, money is scary tight, and i am hopelessly addicted to fishing and duck hunting. after fixing the transom, paint, and rebuilding the trailer, i am not going to have alot left, so i am looking for way to power it for a season, so i can save for a good outboard. i dont want a used outboard because i know nothing about working on them, and the outboard mechs around here charge 60-100$ an hour. plus, if i buy a trolling motor, it will be something i will need/want anyway, after i do buy an outboard.
my question is how many lbs of thrust do i need to push my boat? i will have about 400 lbs between me and my brother, and our gear, 450 tops. i will stay in protected areas until i have a real outboard, so o rough water to worry about. i would like to be able to push into a 10-15 mph wind. is it possible to stay with a 12 volt motor, and have enough power? i was thinking a 55 lb minn kota. if i need any bigger, ill have to go with 24 volts, making me have to add another battery, but i dont mind, if the 55 wont handle it. so i guess my question is can i get by with a 50-55, or should i jump to the 70-80 lb?
and my other question is can i get a 2 mile round trip from a trolling motor without totally draining my battery?
thanks for all your help.
