rscottp
I have a Yamaha F25. Trying to replace impeller, have all the bolts removed and it will not come out. It has loosened a little, about 1/4". Any advise?
Yep, shift rod is disconnected. Feels like the drive shaft is stuck.[url=https://www.tinboats.net/forum/viewtopic.php?p=358227#p358227 said:stevesecotec02 » 03 Jul 2014, 21:36[/url]"]Did you undo the shift linkage bolt? I think on the yammi fourstrokes its two nuts that tighten on top of each other. Should be located on front in the mid section of your outboard.. There is an expoesed section of shift rod and you will see the two nuts. Loosen lower one a full turn then loosen top one untill it seperates.
