Thanks,CedarRiverScooter said:Very cool!
Is that a belt (can't see it well)?
If so, is it notched so it doesn't slip?
Tylermk5 said:Thanks,CedarRiverScooter said:Very cool!
Yes its belt drive. its a 130 mm notched belt.
wmk0002 said:Cool! What was the cost to build? What size motor did you pair it with?
nccatfisher said:Did you make your outdrive unit (tail) or buy it somewhere? That is a neat unit. You have made the wheels start turning now. I have the stuff here to build one, I know there would be a bunch of trial and error involved but that is what makes it fun.
I believe you would adjust that with a travel limiting stop bolt under the pivot. That would limit the travel down. If I am incorrect I am sure he will chime in.KMixson said:Nice! Is there some kind of trim so you can trim down farther than it sits in the picture?
nccatfisher said:I believe you would adjust that with a travel limiting stop bolt under the pivot. That would limit the travel down. If I am incorrect I am sure he will chime in.KMixson said:Nice! Is there some kind of trim so you can trim down farther than it sits in the picture?
