dkonrai
anyone use the hts2000 aluminum rods to fix their tin boat?
jigngrub said:To fix what?
Leaking rivets?
Leaking welds?
Leaking seams?
Leaking welds???
What's the matter with your boat?
cva34 said:I have some and used it Today .Really looks good on my 16f bottem corrosion spots..Time will tell.Useing problems were few .Biggest problem was getting enough heat out of a Mapps Torch .A 16ft heat sink can absorb lotsa heat. There write up said on larger boats ,might have to use a OX/Act with a small rosebud tip.I got a rosebud orderd off EBAY will be here tueday.Clean area well sand,file wire brush right before you put heat on it and tin it like they say then complete weld/braze....cva34
dkonrai said:cva34 said:I have some and used it Today .Really looks good on my 16f bottem corrosion spots..Time will tell.Useing problems were few .Biggest problem was getting enough heat out of a Mapps Torch .A 16ft heat sink can absorb lotsa heat. There write up said on larger boats ,might have to use a OX/Act with a small rosebud tip.I got a rosebud orderd off EBAY will be here tueday.Clean area well sand,file wire brush right before you put heat on it and tin it like they say then complete weld/braze....cva34
got any picts? i have some repairs i need to make. im torn between giving these a try or the marine epoxy.
krawler said:On rivets that are leaking just rebuck or replace them. On leaking seams, try rebucking the rivets and use 3M 5200 and/or gluvit, don't heat it up or that will destroy the seal that's in there.
The crack on the transom, try to hammer it so it closes up a little more, then weld or solder it.
The support bracket on the transom, just use rivets or stainless steel screws along with some 3M 5200.
