Hull support
Rookie1719
Windsor, Ontario
Hey everyone real quick one ... I’m not a fan of removing the middle bench. But I’m trying to build something for my rods ... I’m notoriously known for breaking one each year.
See photo ... if I run two rectangle compartments (8-10 inch wide) is that enough hull strength ? I would replace the foam in the compartments + under the low floor I made for it.
Just don’t want to lose that structural strength to the point it flex badly. Thanks :D
Are you planning on attaching it to the side of the hull also? Looks like it will be ok to me.
Are you planning on attaching it to the side of the hull also? Looks like it will be ok to me. You could just get some holders to attach to the side of a bench that will hold your rods vertically. It would save a lot of weight, they'd be out of the way and you'd have better access to them without having to worry about sacrificing any hull integrity.
If they are fastened tight to the floor, and the floor has transverse stringers under it, should be okay.
The sides really need to be tied together across the middle somehow, to keep them from bowing out and buckling.
Yes. Frame a box which would be fastened to the floor plus I’d add two or three more supports from the side to the box.
Either that or a really stiff rub rail!
