inline fuse - 50 amp - where to buy?
Kbush7
Yesterday, I looked all over the for a 50 amp inline fuse. I've checked Gander Mtn, Fleet Farm, Grainger, Norther Tool, Home Dep, Menard, Ace, etc.
Anyone know where I can get one in MPLS SW suburbs? I'd like to install before the weekend, but if I have to, i'll buy from online store.
Also, I assume that since my TM is a 50 amp, I want a 50 amp fuse, correct?
Thanks for the feedback!
Here you go - https://greatlakesskipper.com/product/86_301-marine-electrical-supplies-misc-supplies/6790-cooper-bussman-bussman-50-amp-80-vdc-in-line-boat-fuse.html
You should also be able to get it at any marine dealer in your area or the Tracker parts counter at Bass Pro.
I'm pertty novice when it comes to electrical components. If my MK TM is a 50 amp, do I need a 50 amp fuse? Then, I read that the fuse/breaker should protect the wire, not the motor. Is this accurate, or does it do both?...I'm lost.
I believe the low end 30 lbs. thrust motor asks for a 50 A breaker, and the larger 55 lbs. thrust motor asks for a 60 A.
Here is what I use (I have both motors):
50 A
https://www.amazon.com/gp/product/B0019QW7GY
60 A
https://www.amazon.com/gp/product/B0007L8BQM
In my area any autoparts store carries the inline fuses, I am sure they would have them in your area. They were cheap enough that I bought 2 just so I would have an extra.
50 A
60 A
Thanks for the links. My motor is a 55lb Edge, so I'll go with the 60 amp fuse, but what gauge wire - 6, 8? It will be a short loop to the battery, about 2 feet each way.
It has nothing to do with trolling motor size. The fuse is there to protect the wiring not the motor. Go with 6ga.
I would suggest getting a manual reset breaker as opposed to a fuse. That way if it ever trips on the water you can just reset rather then replace.
got mine at walmart for 7 bucks
I believe I got mine at Radio Shack. And as Derek mentioned, I'd get a circuit breaker vs fuse.
+1 as well. In fact, the 60 A breaker I mentioned above had its first real test out on the water last weekend. It tripped several times (and I manually reset it), and I'm still not sure of the cause, although a loose connection to the positive battery terminal that I discovered later was the likely culprit.
Also,any car stereo shop would have them.Main in line fuse for car stereo has to be be water proof to be installed under the hood,they have O rings,gold plating for corosion protection...i myself have a breaker (reseatable).
Dan
This is the one I have. It has the minn kota brand on it, but I think it may be made by marinco.
