Cubman
I have a 1648 with a 70hp tiller motor. I moved the cranking battery up front to help with weight distribution. There is about a 15ft run of 4 gauge cable. I would like to add a fuse at the battery in case something rubs a hole in the insulation of the 4ga cable. What style and size fuse should I use?
EDIT: Or what style and size circuit breaker should I use?
