Knapstacks89
My motor acted up all of last year and with the upcoming season I want to get it fixed. I called around to all of the Marine Mechanics in my area and no one would either call me back or had any availabilty because of a lack of labor. So hopefully with the help of this forum I can diag and fix my engine. I will go into as much detail as possible.
My boat is a 1996 Spectrum with a 1997 Yamaha T9.9ELRV. When I purchased this boat the previous owner had everything in the boat running off of one 12v battery. That was the engine, trolling motor, 2 fish finders(Garmin 7SV's), bildge pump, light and did not have a functional livewell.
The issue that I have had with my boat is that when I would accelerate to full throttle the motor would start to sputter out and die. I have gone through a process of trying to trouble shoot this issue, below is everything I have tried so far. Please note that I am currently in the process of redoing this whole boat.
1. At first I believed this was a fuel delivery issue so I replaced all of the fuel hoses, the hoses in the engine itself, fill hoses, hoses from the tank to the engine and a new primer bulb. When running at full throttle I noticed that my bulb would never truely stay hard. I was able to keep the enigine from dying multiple times by reaching back and priming the bulb.
2. When replacing all of the fuel lines did not fix the issue my next guess was the fuel pump. I looked the parts up on Sim Yamaha and ordered a new fuel pump. Since 1997 the fuel pump had been replace with a new verison. The new fuel pump has 4 hose fittings, the old one had 2... So I am still confused on if I did this part right. The first and only time I took the boat out with the new fuel pump the boat ran perfectly never stalled once, it did however start leaking oil from the fitting around the fuel pump.
3. I have tried adjusting the idle, fuel air mixture, spark plugs seem good.
Attached I'll have some pictures I've taken of the engine that may help.My current thought is that the engine was not getting enough juice for the battery to handle the load, I had notice in the past that if I ran all the accesories the entire boat would cut out. I am redoing my boat with a 3 battery system regardless.
Any help or opinions would be awesome.
