Need an opinion please
TinBoats Supporter
Shrewsbury, MA
Honestly this is not a big deal, but I figured I would ask the experts. :D
I want to buy a Tire pressure Gauge. :LOL2: I've narrowed it down to two options that I see on Amazon and can't decide if I should get the short model or the one with the rubber hose.
This one: https://amzn.to/2gYz2bH
Or this one: https://amzn.to/2hIf6J3
Seems like these units get excellent reviews and they come with a lifetime warranty.
Of those two I like the short model better but would get the one with the rubber hose, I would think it would easier to get on the valve stem in certain applications.
As long as the gauge goes up high enough for the PSI your tires are rated for, either one looks good but I feel like the one without the hose could be tough to angle in at some spots.
I need a gauge that goes a little higher since I have an RV and a pickup truck with E rated tires that can go above 50psi. Just something to consider.
Ok that was my next question because they have this one: https://amzn.to/2hIqCUy
Im really just checking my Silverado tires and don't have an RV or motorcycle. Should I just get this one for the heck of it?
For car tires either one will work. The one with the hose will be easier to read after placing the end on the tire stem but two hands make it easier. The small one will be little harder to read in some instances but you can use one hand in most cases. I do like the 60 PSI gauge over the 100 PSI gauge for car tires because you can get more precise reading.
the newer types of handheld gages have a pressure hold feature.
so when you remove the gage from the tire valve, the needle stays
on the pressure it last registered........ easy to read - nice feature to have.
then, press the release button and the air is released and the needle goes back to zero.
store the gage with the needle on zero - no internal pressure.
I got mine from AutoZone for about $7 but it only goes to 60psi and the nipple does not swivel (a bonus).
my next one will be as the short stem that you posted to 100#
and the numbers appear easier to read.
To me the big difference would be that the solid gauge might be easier to use with 1 hand. The hosed gauge would flop around unless you hold it with other hand.
Long hose is preferred, the gauge will hold the pressure reading until the release button is depressed.Center scale of the gauge will give the best accuracy, in this case 30psi. Rubberized case will help protect it from some abuse but not much. With the hose you can reach much better and concentrate your efforts on making a great seal when measuring at the valve stem. The gauge with no hose can be difficult to hold just right and could give false pressure readings.
I've had one of those for years and it's always worked great!!
I've had really good luck with the electronic gauges over the years. I tend to have several gauges because of multiple motorcycles and a car and truck. The nice thing is that it's kind of neat to compare them to see how close they are.
Typically the electronic ones are within a 1/2 pound of each other.
Definitely not. I like my bacon limp and to the point where it melts in your mouth.
