Xterminator GT
- Joined
- Mar 15, 2012
- Messages
- 48
- Reaction score
- 0
I'm looking for opinions/advice on a new boat for a 25 Johnson jet. Thinking a blazer 16/42. The boat will be used for river riding and gigging mostly.
Lil' Blue Rude said:I like my 16' 42" SS pretty good. Some time I wish I had a 48" but I do like have that little extra clearance when running tight spots. the 42 takes a little more throttle to keep it up on plane but I have seen a kid with a 16' 42" SS with a 50hp yammy on it that would launch. It beat my 2 cylinder out of the hole but I run it down in the first 300ft. I'd get the all aluminum transom. Don't know if your doing tiller or steering console but if your going with a console I'd put pedestal seats in front of the bench just to get a little weight forward. That should put you in the ball park of the boats center of gravity depending on how much weight you have where. That way you won't have to worry about the rear end being to heavy and it slapping all the time. At the same time I'd get a shorter built in deck an if you want it longer add a removable flip up deck. 48" deck on a 42" weighs around 75lbs. 75lbs at the front of a 16' boats is about the same as 300lbs at the back. Plush the lighter front end makes it easier for the boat to carry the nose so if it does slap it doesn't come down as hard.
Are you thinking about a plain blazer or a sport? Think I'd go with a sport if I was going to use it for a riding boat part of the time.
