Probably 4ga would do it.. I usually buy a set of booster cables and cut the ends off.. if you get a decent set on sale it's cheaper than buying the wire individually.Johnsk said:Any recommendations on gauge wire when moving start battery up front I’m thinking 2-4 gauge it’s 12 ft run
Yep, that is what I did.GYPSY400 said:Probably 4ga would do it.. I usually buy a set of booster cables and cut the ends off.. if you get a decent set on sale it's cheaper than buying the wire individually.Johnsk said:Any recommendations on gauge wire when moving start battery up front I’m thinking 2-4 gauge it’s 12 ft run
Sent from my SM-G903W using Tapatalk
Weldorthemagnificent said:I've used jumper cables for years. Starting a small outboard is a small momentary load, smaller than any car. And the charging current is low. Might be different on a larger motor.
