RivRunR » 30 Jul 2013, 07:37[/url]"]Best practice is to use tinned marine wire, and crimp connectors that have built-in heat shrink with adhesive.
Here's a couple of sources:
Tinned Marine Wire and
Genuinedealz
Wire gauge depends on the amp draw of the device and total length of the circuit ( pos + neg).
For the lights, 12AWG should be fine.
Fish finders usually use very small gauge, like 16AWG or less, gauge the wire supplied with it or your manual should say.
For the live well you should try to find the amp draw of the pump(s) and aerator, and then use a chart to figure out wire gauge. Here's a
Wire Size Chart
If you're installing nav lights, you'll either need 1 DPDT (on/off/on) switch to handle both lights, or 2 SPST (on/off) switches, one for each light (bow and stern).
A fuse panel and ground bus bar make for a neater install, and also make it easier to add more circuits later.
It's also a good idea to put a circuit breaker between the battery and the fuse panel.
Hope this helps.
