Here is a link that you should check out. It might not be the exact part you need, but it gives you some idea of what is available. The description says it is a plastic internal tank designed to replace your old, metal one. There is also a link below for a conversion kit. I was under the impression that there really was no simple, cost-effective way to convert to an external tank, but I may have been mistaken. Worth looking into.
Replacement plastic integral fuel tank for Nissan 5hp 2 strokes
https://www.internetoutboards.com/partdetail.asp?id=320
External fuel tank conversion kit for Nissan 5hp 2 strokes
https://www.internetoutboards.com/partdetail.asp?id=1059
Please check to make sure you've got the right part before ordering. I did not verify specific part numbers for your application. Good luck. Hope this helps.
