Old Johnson Transom Mount Trolling motor - Info needed
topgun15v
North Dallas, TX
I just bought this trolling motor off Craigslist yesterday for $30, and it doesnt have any info on it. I tried a bunch of google searches and nothing. What lb thrust? 12 or 24volt? any other maintenance i would need to do? It works good, but when the prop spins it sounds kinda loud, i was thinking about greasing around there? Any info would be appreciated. Thanks
That looks awesome!! As far as the sound from the prop, it could be fishing line stuck there, it looks difficult to remove the prop, but if you can, clean the shaft.
Thanks man. I just checked and there is a little pin holding the prop in place. Ill try and remove it tomorrow and check it out. Thanks for the response.
