TrackerTom
- Joined
- Jun 4, 2009
- Messages
- 97
- Reaction score
- 0
Ok so everywhere I read and from Mercury the plate should be even with the bottom of the boat. Then, I call Tracker Marine who built my boat and ask them about my exact motor and they tell me it should be mounted on the transom sitting directly on the top rail which puts the plate 1.25" below the bottom of the boat. What's up with that? If best performance is obtained with it even with the bottom, why in the world would they mount it lower? I'm considering getting a 4" manual jack plate and setting it even to see what happens. Though my performance is respectable with it setup as is. It's a 1654SC Grizzly with a 4 stroke EFI 40 with the prop that Tracker recommends, a 10.38 x 13P factory one, and it runs an occasional 30 MPH with just me and usually 28 MPH. Of course I would like to get all the speed out of it that I can, but I'm not sure I would get much more considering that the calculated speed with no slip on my current prop is only 36.8 assuming that it reaches 6000 rpm. I'm trying to come up with a smartcraft tach to check this, but it takes a bit of $$$ to get a tach hooked up to the mercury EFI's so I figured I would just go with the smartcraft. Anyway, do you think it's worth jacking the motor up?
Thanks,
Tom
Thanks,
Tom
