catmansteve
So my friend's father has a small fiberglass jet boat that he wants to get rid of, and I'm curious to know if anyone here has ever heard of the boat/motor or considered using the combo for an inboard jet jon. The boat is a 1988 Jetstar 1250, 12.5' fiberglass 3-seater speed/ski boat. From what I can find it was made by the Ultranautics company, they also made a Wetbike and a conventional PWC with the same engine/pump. The hull is in rough shape and leaky, but the boat is all together and runs fine aside from the leaks, and I can buy the thing for a song basically.
Now the interesting part: the engine/pump combo is similar in design to a Mercury Sport Jet. It uses a verticle shaft Suzuki 50 hp outboard powerhead that sits on top of an aluminum intake/pump. I've ridden in the boat before, it runs about 30-35 mph with two people, and according to the spec sheet the dry weight of the boat is 700lbs, the motor itself weighs about 150lbs. I'm going to guesstimate the dimensions of the engine compartment to be 30" long by 18" wide by 24" high. I'm thinking the motor would be perfect for a medium sized jet-jon fishing rig, either a 1448 or 1648 hull, and would have a much smaller footprint as well as a more straightforward fabrication than a jet ski motor/pump.
Does anyone have any knowledge or experience with these boats or motors? Anyone ever heard of this engine/pump being used for a jet jon?
