I hunt yotes mostly at night, but some times during the day too. Wind is the key, play the wind ALWAYS.
This is what usually always works at night.. I use a Redrock tape caller.
First you use a locater call (coyote howling) for about 3-5min straight , if you hear them howl back it's on like donkey kong! Usually!! Wait about 5min This is where I change my game up from time to time when hunting the same spots over and over Use either a woodpecker or cottontail in distress call for 3 or so min straight, then stop and give it a few min then scan the area with a spotlight w/red lense (night hunting) be ready to shoot!! This is usually all it takes for me to bag one. Now if you don't see anything hit the locater again3-5 min but this time start your volume loud and slowley turn it down over the course of the 3-5 min. If you don't get a response back then they are either creeping in or burning out . Wait a few min then try the same distress call you used before this time start loud and work the volume low like you did your second locater sesion. Let it play a couple of min on real low volume this will bring a coyote / fox or bobcat in close. Scan the area with a light and be ready to shoot!! Most of the time you will see their eyes before anything when you do keep the light on em until you can ID the target then Give it to em! If you take to long or take the light off of a predator it will surely disappear, you normally get one chance when your at this point make it count.. If I don't locate a coyote within 20-30 min I usually switch stands, and try again.
