mcontrer82
- Joined
- Mar 4, 2012
- Messages
- 41
- Reaction score
- 0
Hi, I am new to this forum and I have been looking around for the past few days. I have a 1436 alumacraft and I wanted to add some seats. I have seen several of you who have done that by adding the plywood to the bench. This is the way that I want to add them. I just had a few questions before I attempt to install them this weekend. This is what I have purchased already.
https://www.academy.com/webapp/wcs/stores/servlet/Product_10151_10051_10773_-1?N=581132421
https://www.academy.com/webapp/wcs/stores/servlet/Product_10151_10051_10755_-1?N=581132421
https://www.homedepot.com/h_d1/N-5y...&langId=-1&keyword=toggle bolts&storeId=10051
My questions are (1) Should I use 1/2" plywood or 3/4" plywood? (2) Do I need to find stainless steel toggle bolts or are these fine? (3) What size drill bit do I use and how do I make the center hole for the pedestal base? (4) Do I just drill through the plywood and the bench seat at the same time or are the holes in the bench bigger? Any advice would be helpful. I just don't want to mess this up. Thanks.
