Replacement Rivets ?
mightymite45
Rustburg, Va.
I have a 1448 polarkraft that I'm relocating the bench seats in, and would like to use the same kind of rivets to put back in! Does anyone know where I can find these aluminum rivets and what they are called or the size I'll need? Any help would be greatly appreciated ! Thanks.
Hey mighty, I've never owned a Polarkraft but I'm guessing they used solid rivets? If you want the exact material they used in the factory, the best bet may be to give them a call and ask. I generally get my rivets from either my local Fastenal or Drillspot.com. But there are a lot of companies that you can order form online.
https://www.imperialsupplies.com/grp127.shtml
Give that a look. You'll need bucking rivets.
