Johnson 15hp 1984 electric start.
Well, not really stuck just hard to move with the engine off.
Now that I’m up and running I’m looking into the finer points of outboard motor usage. I’ve very careful to shift to neutral before shutting it off, but a couple of times I’ve had it die while in gear and low idle. It’s hard if not impossible to shift it back to neutral, and I don’t want to break anything. It’s apparently far enough toward neutral that the engine will turn over but it’s hard to start. I have to fiddle with the choke, all the while drifting down river, but have been able to get restarted.
Ideas?
Thanks
Ideas?
Thanks
