Switch Panels witout fuses
cstallings
Greenbrier, Arkansas
Does anyone have them? I'm having a hard time locating them. I think I'm going to use a fuse panel, so I don't want fuses in my switch panel. I'm going to have some devices not on a switch, so I think it would look cleaner to use a switch panel and fuse panel with a (-) busbar and avoid the inline fuses. I could probably make one, but would rather buy one.
Thanks!
The switch panel I have is fused, but I am just going to cut the wires before the fuses to get rid of them and then wire it to a fuse panel like you are talking about.
It doesn't matter if the fuses are not on the switch panel as long as they are within 7" of the power source that feeds the switch panel as per ABYC requirements.
You can get a 4-position un-fused panel from New Wire Marine, but it sure ain't cheap. They also have various panel blanks, switches, and actuators that you can use to build your own.
I've never ordered from them, but they do seem to have a pretty good selection.
