sturdi87
Just got home from fishing the ohio river, some backwaters of the ohio river, and some creeks. We have had a lot of rain and there was a decent amount of debris in the water that cleared up for the most part by around noon or so. Anyways, when I pulled the boat out of the water and tilted the motor up one blade on the prop had this crack in it:
As you can see the prop was already in pretty bad shape with lots of dings and chips. The bent out edge on that blade was already like that. I was already thinking about getting a new one and using this one for backup sometime soon down the road. I didn't hit anything big really unless that one blade caught something maybe? The only decent size log I hit was at idle when i was going into some backwaters from the river; walls of debris form at all these areas and it was floating just an inch or two below the water, covered up by a bunch on small sticks and stuff floating just over it. I didnt think it hit the prop, actually I was basically sure of it at the time, it felt like the hull pushed it to the side, but maybe it did hit it. I couldn't see any marks on the skeg that looked fresh or different.
So Memorial Day is coming up and I have the day off work so I would like to use the boat has anyone ever tried doing a repair on an aluminum prop with JB Weld? I figure it can't hurt to give it a shot? I figure it might last until the next time I hit something, which will happen as much as my boat sees the river and creeks.
I figure this thread will stir up some stuff so let it go lets here what you think!
