answer3
Hi guys
I never boat a boat before (except a new canoe...) so I don't really know what to check before buying an aluminium boat. From what I read so far here I am planning to check for:
- weak/rotten transom
- obvious cracks on the hull
- leaky rivets
- holes in the hull
However I don't really know how to check those things...
How do you check for leaks if the boat has floorring or if the seller does not want to fill the bottom of the boat with water?
How do you know if the transom is in bad shape if it is enclosed in aluminium? Is trying to wobble it by hand informative enough to tell if it is in good shape or not?
Is there anything else to check before buying the boat?
These days everything is frozen where I live so testing the boat will be challenging... Can I trust an outboard by just starting it in a big trashcan full of water and seeing that it starts first or second pull?
Sorry for all those naive questions... This is the first time I want to buy a boat and have no clue what to check. I guess that if the boat is cheap and in rough shape I don't have much to check and will probably have to fix everything and if the boat is in perfect shape it will be fine, but I am wondering all these questions for boats in average/medium shape (which will probably be most of the ones I am going to see...)
Thanks in advance for your advices!
Damien
- leaky rivets
- holes in the hull
Damien
