De Hoog
Finally finished sanding, primer/painting and putting my trailer back together. (pics will be coming) I bought new LED submersible lights and installed them. When I plugged in the trailer, I only get a single, very dim light smack dab in the middle on each tail light. I know I have the grounds on bare metal because I used my Dremel with a wire wheel to get down past the paint and primer. I checked all fuses on my truck (all good) and then I plugged in my other boat trailer with incandescent lights and it worked just fine. I have checked the plug-in numerous times, rechecked my grounds numerous times, made sure the wiring was correct. Any suggestions? Do you think I have a bad set of lights or am I missing something?
