Transom replacement
Ok. I need to replace the rotten wood. Everything is welded and the only option I see is to cut welds and hopefully remove the braces. Then slide the wood down and put new one in. Then replace the braces . My question is would it be better to re weld or to use bolts?
If it were mine ... I'd make 'smart' cuts as needed to then allow it to be bolted back together the strongest that I could. Those supports from the floor angled up to the transom are called the 'knees' and I'd keep them affixed to the floor, as with that side flange, you can then bolt them back in place up top to the new transom.
Simple way, once you get the 'top cap' out of the way:
https://www.tinboats.net/threads/new-transom-for-tiny-tinny.43039/
Now this post here may be overkill, but this is how I do replacement transoms and maybe it will give you some ideas.
https://www.tinboats.net/threads/new-transom-–-1976-starcraft-‘holiday-15’-model.47405/
Yes, transom can last forever, make pattern, 3 layers of ext. Plywood 3/4, glue together(gorilla glue, the foaming type) screw together, let set(week), scape off excess, mix fiberglass resin with hardner then cut 1/3rd with acetone then start coating with roller multiple coats, it soaks in good, as I said , multiple coats, quickly before it gels up, let dry and get hard. Waterproof forever, never rot. I've built many, Never had one go bad in 40yrs.
My Jon was basically the same. I drilled out braces like your, this allowed me access to remove and replace new wood. I used regular ply as my thought was if I’m covering it with fiberglass resin I won’t need treated ply. I glued two sheets of 3/4 together (clamp and screwed). Then coated in resin, two coats letting dry overnight in between coats. Took several days as I only did one side at a time. I sand lightly between coats and used a brush. Don’t do it in the sun.
I also found an old road sign that I cut a piece of aluminum out of. Use that in the center where motor mounts so it wouldn’t compromise the resin.
When I have replaced a small boat transom, I havent gone as far as many of you have. I look at it this way...if it lasts my lifetime, then who cares...some of these transom builds are quite comprehensive, the transome will be there long after the rest of the boat has returned to dust !! LOL..
Cut it all out and build a aluminum brace then weld a new sheet of aluminum plate. Get rid of the plywood. It will be stronger and last forever.20211016_091315.jpg20211016_091328.jpg20211016_091345.jpg20211017_102234.jpg
Great idea, but unfortunately, most folks don't have the acess, skills or equipment to handle such a task, therefor the plywood becomes the go to material. If done properly and stored properly plywood will last a lifetime or close to it.
