chrispbrown27
First question, i am looking at a new sonar unit. I want/need something with gps and would like to step up to down imaging (in a perfect world I could afford a unit that would have gps, down imaging and side imaging, but that's just not a possibility). I have been looking at the humminbird 500 series, specifically https://store.humminbird.com/products/604319/581i_HD_DI_Combo and https://store.humminbird.com/products/604322/587ci_HD_DI_Combo. The only real difference is that the first is a greyscale model and the second is a color model. Having no on the water experience with either one, the videos I have seen appears that the color makes bottom hardness and other objects stand out more, but thats a pretty significant price increase for some color. So what is everyone opinion on this? Is it really worth shelling out the extra money for the color unit or, just stepping into the down imaging world, will the greyscale suit me just fine?
Second question, what onboard charger do you guys run? I have read that Noco is supposed to be one of the best out there and the prices aren't too awfully bad, any other recommendations? I would be looking at a two bank, possibly a three bank if I decide to go with a separate battery for starting the outboard. I would like something that I can plug up and not have to worry about monitoring the charge level, I want to just plug it up and let it go til the next trip. Also, is there a some sort of an insulator out there or wrap that can be used to protect a battery for outside winter storage? Right now I am running a single battery and I pull it out when I get home from duck hunting, but if I start running two or three batteries pulling all of them out after each trip to prevent freezing issues will be a real pain.
Final question, I have noticed that few companies are making marine cranking batteries these days they seem to have almost all switched to dual purpose batteries. My understanding is that a dual purpose battery barely works as either a deep cycle or a cranking battery, since both operations require different designs. Should I look for a cranking specific battery or just get a dual purpose? Also, how small can I go? I will be moving the two deep cycles to the center bench to open up room in the back of the boat and would like to find the smallest starting battery that would get me started everytime. What do you guys recommend?
Chris
Chris
