FLbassBLASTER
- Joined
- Apr 13, 2015
- Messages
- 14
- Reaction score
- 0
I know I'm probably beating an already dead horse further to death, but I work a lot and don't have a whole lot of time to browse this forum. If you're one of the seasoned vets I know are here, your knowledge and time would be greatly appreciated by this first time builder.
Ok, so I'm doing a 1432 conversion, and I want to run a fairly basic electrical system. At first, the boat will be a slow moving electric (until I can afford a decent little outboard), but I have a number of small honey holes I can get to where that's not a problem at all. Down here in FL, those tiny <100 acre bodies of water are where the monsters lurk.
Electrical system (A) will be composed of :
-Group 29 deep cycle battery
-6 gang switch panel w/fuses https://www.amazon.com/gp/product/B004XADSUM/ref=oh_aui_detailpage_o00_s01?ie=UTF8&psc=1
-Anchor Light
-Nav Light
-Deck Lighting
-Bilge Pump https://www.amazon.com/gp/product/B00EPU0C5E/ref=od_aui_detailpages01?ie=UTF8&psc=1
-Dual 12v outlet (One cig outlet on one side, 2 usb outlets on the other)
-Humminbird PiranhaMAX155
Electrical system (B) will be composed of :
-Minn Kota Endura C2 (30#, 30")
-Group 27 Deep Cycle
![Boat wiring Diagram 1.png Boat wiring Diagram 1.png](https://cdn.imagearchive.com/tinboats/data/attachments/63/63581-1f791d07070a774b89d98b6541f8a68c.jpg)
For the purposes of this diagram, I'm just going to say that each of the items in (A) are going to use a 5 amp fuse... Once I've got everything in my hands, I'll be able to see exactly what fuses to put in.
I'm going to build a small side panel console deal to house my switch panel and outlet, and for now at least, both batteries will be in the stern.
If my fuses add up to lets say 27 amps, and that's how it will be staying, do I need a circuit breaker that's close to that (30) or could I get away with something bigger (50) that I've got laying around?
When calculating the length of a run, is it double the length of the wire? From what I'm looking at, I think I should be ok with 16AWG Marine Tinned Wire for (A). The furthest thing from the battery will be the Anchor/Nav lights, and that'll be a total distance of about 15', so would the run be 30'?
For (B) Initially, the trolling motor will be transom mounted, and not very far from the battery at all, thus not needing any additional wire. Once I get my outboard, the trolling motor is going up front. I know thats still a ways down the line, but would 4AWG be good enough to have my trolling motor 15' from my battery? Obviously going to have a CB included as well.
This is my first shot at wiring anything like this, so any advice or constructive criticism will be greatly appreciated!
-Anchor Light
-Nav Light
-Deck Lighting
