MRichardson
I'm slowly learning the ins and outs of outboard service (the hard way, apparently). I'd certainly appreciate any insight or thoughts on what I'm dealing with here...
I have a 1994 25hp Merc that has been running on 1 cylinder. The first time it happened, I put it in saltwater and the cylinder was firing intermittently, it was in/out and then settled into firing fine and I ran around that day with no further problems. Next time, took it to the coast (saltwater) it cranked up fine but only 1 cylinder was firing no matter what I did. So I took it apart, checked compression, gaskets, plugs, etc., took it to the lake and it ran great. It ran great for several trips to the lake, screamed like a banshee. Took it this weekend back to the salt, and again, only running on one cylinder. Pulled the plugs, cleaned em a bit with a file and then it was intermittent. Aha! I thought, got a bad plug. Played with the leads and found it was the top cylinder. Replaced with brand new plug. Still ran intermittently for a bit, then finally kicked in and ran good after kicking in and out for a bit.
What the h*** is going on here? I doubt the water (fresh/salt) has anything to do with it, probably just a coincidence that it keeps failing in salt, working fine in fresh? Unless some sort of electrical stuff is going on... I don't know.
Where would you start next in diagnosing the issue?
